2003 Kia Sedona vibration
MAXWELL117
Noises problem
2003 Kia Sedona 6 cyl Front Wheel Drive Automatic
My 2003 kia sedona has a bad vibration in the front end. It happens when going any faster then 30 mph. The van is running fine. I do have a another noise of a fan that squeals when i turn the fan for heat or air. It only squeals when it is turned on. Not sure if this is related. What is it? It is so loud
Nov 23, 2009 at 3:21 PM
  • 31,937 POSTS
Hi there, thank you for the donation,
I would be having the tyres & wheels checked for any deformity, a wheel balance will suffice for this, also have the steering & suspension checked for any worn components, the fan noise will more than likely be a dry fan motor bush or bearing.
mark (mhpautos)
Nov 23, 2009 at 3:29 PM
