2003 Kia Sedona timing belt
104,000 MILES • 6 CYL • FWD • AUTOMATIC
JOEYDUSMC
2003 kia sedona 104000k miles. At idle with foot on break rpms race. Also a rattling noise on start up which goes away after a few minutes. Also loss in acceleration. Is this a timing belt problem?
Oct 12, 2009 at 2:25 AM
  • 110,248 POSTS
Honestly, what you described sounds like a catylatic converter problem. The internal parts in the converter come loose, rattle then block the exhaust. I would check that first. When the engine is cold, take a rubber mallot and tap on the converter. Listen for something ratteling inside. If you hear it, replace it.
Let me know what you find.
Oct 12, 2009 at 6:30 AM
