2003 Kia Sedona ac leak
95,000 MILES • 6 CYL • 2WD • AUTOMATIC
JCALVIN77038
help i had replace the compressor about a year ago the ac evap last month i sniffed and used a black light still leaks its last about month or so i check the lines under the van running to the rear evap i also pulled the rear blower motor a used black light i can find it
Jun 22, 2010 at 9:01 AM
  • 31,937 POSTS
You will have to persist with either dye leak test or an electronic sniffer, both should locate this leak, make sure you sniff in the vents for a evaporator leak.
mark (mhpautos)
Jun 22, 2010 at 12:24 PM
