2002 Kia Sedona replacing right sided door handle
47,000 MILES • 6 CYL • FWD • AUTOMATIC
HGARRANCHO
what's involed in installing a new handle/lock mechanism
Aug 31, 2009 at 2:13 PM
  • 110,248 POSTS
You need to remove the inner door panel to access the handle. Then it is just a matter of disconnecting the linkage (clip) and unbolting the handle You shouldn't have a problem.
Sep 1, 2009 at 9:54 AM
HGARRANCHO
how do you remove the door panel on the right door of the sedona
Sep 1, 2009 at 12:26 PM
  • 110,248 POSTS
THere are a few screws that need removed, the arm rest, and then clips between the panel and the door. NOTE: The screws in the arm rest will most likely be covered with plastic plugs. Just pop them out with a small screwdriver.
Sep 1, 2009 at 12:56 PM
HGARRANCHO
will I need to buy anything more to replace after I take the panel off the door - screws, clips, etc.?
Sep 2, 2009 at 12:20 AM
GBALABIS
[quote:cefccb5414="Jacobandnickolas"]You need to remove the inner door panel to access the handle. Then it is just a matter of disconnecting the linkage (clip) and unbolting the handle You shouldn't have a problem.[/quote:cefccb5414]
I need to fix the exterior door handle on driver side sliding door. How do you remove the inner panel?
Jul 27, 2010 at 4:57 AM
