2002 Kia Sedona plug wires
ROBERT70
Electrical problem
2002 Kia Sedona 6 cyl Front Wheel Drive Automatic
I need to replace the plug wires, do I have to replace the wires and the boots? or can I just replace the wires? How many wires are on a Kia Sedona? Can you help me the parts stores around here have no idea.
Aug 31, 2009 at 7:44 AM
BLUELIGHTNIN6
  • 16,542 POSTS
the boot is connected to the ignition wire so the entire thing will need replaced. your vehicle is a 6 cylinder so it will have 6 ignition (plug) wires. be sure to replace only 1 at a time to avoid mixing up the cylinders as this will cause engine to run inproperly.
Aug 31, 2009 at 9:23 AM
