2002 Kia Sedona NOISE IN ENGINE WHEN SPEED HITS 50 MPH
57,700 MILES • 6 CYL • FWD • AUTOMATIC
DAVEHAGEN
I HEAR A NOISE FROM THE ENGINE AREA WHEN I GET ON THE HIGHWAY AND REACH 50 MPH BUT I NOTICE IT STOPS WHEN I TURN THE STEERING WHEEL TO THE RIGHT BUT COMES BACK AGAIN WHEN THE WHEEL GOES STRAIGHT AGAIN CHOULD THIS BE A PROBLEM WITH THE POWER STEERING PUMP OR BELT THAT CHOULD MAKE THIS NOISE ? THE FLUID LEVEL IS FINE IT IS DRIVING ME CRAZY ANYTHING I SHOULD HAvE A MECHANIC LOOK FOR OR MAYBE ITS NOT THE POWER STEERING AND SOMETHING ELSE BUT ITS ODD THAT THE NOISE STOPS WHEN I VERE TO THE RIGHT ANY HELP APPRECATED
Jul 2, 2009 at 1:54 PM
  • 110,248 POSTS
Chances are if it goes away when you turn right, you have a bad wheel bearing in the right side of the car. When you turn right, you take weight off that side of the car and a bad wheel bearing will normally quiet.
Lift the vehicle and check to see if there is any play in the wheels. Check both front and back.
Let me know what you find.
Jul 11, 2009 at 4:10 PM
DAVEHAGEN
IT was the wheel bearing and it had it fixed and it no longer makes the noise thanks for the help
Aug 2, 2009 at 1:20 AM
  • 110,248 POSTS
I'm glad you found the problem and it's fixed. Let us know if you have any other questions in the future, and thanks for using 2carpros.com.
joe
Aug 2, 2009 at 8:39 AM
