2002 Kia Sedona engine/drive noise on a 2002 Sedona
2002 KIA SEDONA
136,000 MILES • 6 CYL • FWD • AUTOMATIC
DN4192
  • 86 POSTS
Okay this is an interesting issue I am having with my 2002 kia sadona mini van. Every time I first drive it after it has sat for a good long time (more then 5 hours) when I put it into gear, either D or R i hear a sound from the engine area until I fully accelerate. I can leave the car in park or neutral and rev the engine and don't hear it. Once the car warms up I never hear it at all. The only time I hear this sound (like a grrrr sound) is when the van is cold and between idle speed and say 5 miles an hour, because as I excellerate the sounds goes away. What might this be?
Oct 29, 2010 at 4:59 AM
  • 110,244 POSTS
Have you checked for vacuum leaks?
Nov 5, 2010 at 6:17 AM
DN4192
  • 86 POSTS
Would a vacum leak sound go away as soon as you step on the gas or after the car has warmed up? how would i check?
Nov 5, 2010 at 8:17 AM
  • 110,244 POSTS
When accellerating, the vacuum drops, so it would get quietier. You could check the vacuum with a vacuum gauge. Most parts stores lend them or rent them.
Nov 5, 2010 at 6:31 PM
