2002 Kia Sedona Dashboard Lights
WTOMFLY
Electrical problem
2002 Kia Sedona
All the lights on the dash which normally turn on at night
went out at the same time. These are NOT the indicator lights like high beam, door open, etc. They illuminate
speedometer, radio buttons, etc.
Are all the instrumentation lights powered by one bulb?
If so, how do I access it?
Thanks
Nov 11, 2008 at 7:12 AM
2CARPRO JACK
  • 11,533 POSTS
Fist check the fuse in theunderhood fuse box labeled "int fuse" it is a 10amp. then check the fuse in the left side fuse block inside the vehicle,"room" fuse also a 10amp. If both are ok, you need to get acess to the dimmer for the lights and use a test light to see if power is getting into the dimmer and back out of it
Nov 11, 2008 at 1:02 PM
KREMPEP
All the bulbs,switches, and fuses are fine.
it must be sensor or some unrelated problem. I'm still working on it and will post my solution if I ever figure it out. I doubt you'll get a definitive answer on this site. Good Luck!
Dec 19, 2009 at 3:11 AM
2CARPRO JACK
  • 11,533 POSTS
Did you check the dimmer (rheostat) to see if power is getting in and out? I gave you the info on where to start, this is yout first response back. Cant help you if you dont reply
Dec 19, 2009 at 4:03 AM
RICHARD GOOD
Hi where is the rheostat? And has the sedona got a DRC relay? I hunted high and low looking for it.
May 11, 2016 at 7:04 PM
