2002 Kia Sedona cold starting moving automatic stick to rev
58,500 MILES • 6 CYL • FWD • AUTOMATIC
DAVEHAGEN
i need to let the car warm up for at least 4 minutes before i can move the stick shift on my automatic transmission through the gears from reverse to drive i cannot do this when first starting the car the stick will not move so i have to let it warm up and come back 4-8 minutes later before i can move the shifter through the gears does the shifter need to be lubed or something so it does'nt stick or is this something bigger i have the 10yr 100,000 power tran warrenty
do i need to let the dealer see this or is it something minor that i can bring it to the local AMCO and have them look at it and correct it for a resonable fee any help apprecatied thanks
Aug 2, 2009 at 1:40 AM
DOCFIXIT
  • 18,828 POSTS
Hi
I would proceed to dealer and let them repair under warranty. If you let somone else at it they may void warranty. There is no lubing or simple fix. Neds to be seen by a trained Technician.
Thanks for donate
Aug 3, 2009 at 4:44 AM
