2002 Kia Sedona CODE: P0118
114,038 MILES • 6 CYL • FWD • AUTOMATIC
SYPHONFILTER77
Two days ago, the check engine lamp came on while driving. I did not notice anything different in performance. I used a code reader to see what was up and I got a code P0118(Engine Coolant Temperature Circuit High Input). The next day. I started the van and noticed that the engine cooling fan came right on and stayed on with a cold engine. Also the rpm were lower than normal and it felt like the van was going to stall. Any advice where I could start troubleshooting? Thank you.
Sep 14, 2008 at 8:26 AM
  • 75,988 POSTS
Test the coolant temperature sensor warm and cold not to specs replace it.
Sep 14, 2008 at 8:36 AM
TIFFANMOE
Did you find a solution. I have an 02 Kia with the same problem and the same code?
Jul 14, 2016 at 8:17 AM
