2002 Kia Sedona 2002 Kia sedona engine codes transmision pr
2002 KIA SEDONA
78,000 MILES • 6 CYL • FWD • AUTOMATIC
COWPIE12674
These symptoms are as reported by my wife. I have not had the van do this to me personally yet. My van will intermittantly have a problem when I start the engine then put it in reverse it starts to shutter violently and the RPMs drop to almost zero. If you put it back into park and shut it off, then start it again it often doesn't do it again. The check engine light is on and I had the codes read and they are as follows:
P0755- Underdrive solenoid valve system
P0760- Second solenoid valve system
P0770- Reduction brake solenoid valve system
P0350- Ignition coil primary/secondary circuit
Just looking at the names on the codes, my first thought is transmission change. How hosed do you think I am? Are any of these items located inside or outside the transmission or are they not even related? Any insight you can offer would be appreciated.
Nov 9, 2009 at 11:23 AM
DOCFIXIT
  • 18,828 POSTS
Hi
P0755-760-770 are for low reverse solenoid which is inside trans on valve body.Procedure drop pan ohm check solenoid replace if out of specs.Also maybe oil temp sensor or ECM.
P0350 maybe short from coil to ECM, coil itself,wires or plugs. Really need a scan tool for this so a trip to repair shop seems your next step.
Hope this helps
Thanks for donate
Nov 10, 2009 at 6:45 AM
