Login
Join
Ask a Question
Questions by Vehicle
Repair Topics
Testing / Diagnostics
Repair & Service Guides
Symptoms
Warning Lights
Trouble Codes
How It Works
Videos
Login
Become a Member
Home
Kia
Rio
Engine
Timing Belt
Replace/Remove
Kia rio 2006 1.6
2006 KIA RIO
120,000 MILES • 1.6L • 3 CYL • MANUAL
MERCURY 12
MEMBER
The timing belt broke and when I replace I don't have compression in cylinder 3 and 4 what is the problem?
Jan 29, 2016 at 9:24 AM
SINBAD271
Experienced Mechanic
Hello , it's possible to have bent valves or bad pistons.
Jan 29, 2016 at 12:36 PM
MERCURY 12
MEMBER
Thanks, I will remove the head and check
Jan 29, 2016 at 1:13 PM
HMAC300
it'sn interference engine you probably have bent valves
Jan 30, 2016 at 1:53 AM
MERCURY 12
MEMBER
Thanks, I'm still working
Jan 30, 2016 at 8:04 AM
Add image or video
Ask a new question
Engine won't start
Check engine light
