2005 Kia Rio Car stutters???
67,000 MILES • 4 CYL • FWD • MANUAL
LILMOMOF2
My car did this once before and straightened itself out. This time it won't, so I need some help.
When starting it starts correctly and promptly, no issues aside from the engine light being on. Was told this was a MAFsensor/air filter code.
I put the car in reverse, apply gas and it will move than act as though there is no gas getting to it. Sort of like it will die but it never does. When letting go of the gas it idles normally. I cannot get the car past second gear due to the lack of power/gas/air or whatever.
I was told the O2 sensor on bank 1 was reading too lean, but I would think that means the sensor is fine since it can read what is wrong.
Question is, how do I fix the problem, and what is the problem?
Oct 17, 2010 at 10:22 AM
  • 110,248 POSTS
I would start by trying to clean the MAF sensor. They make a special cleaner that you can get from a parts store. If it is reading wrong, it could set the lean mixture code.
Let me know what you find.
Oct 20, 2010 at 3:36 AM
