2005 Kia Rio Blown Fuse
33,000 MILES • 4 CYL • 2WD • AUTOMATIC
DBART03
The 10 amp fuse which controls the power windows and turn indictors is constantly blowing when the air conditioner is turned on. This only started about a month ago. What could be causing this problem? Thanks.
Aug 2, 2010 at 1:32 AM
KHLOW2008
  • 41,812 POSTS
Hi dbart03,
From our database, the power window is not related to the turn signal fuse. Apart from the components decribed, is there any other components which are not working?
Aug 2, 2010 at 1:47 AM
DBART03
Your database might suggest that the two are not related, but I experience the problem daily. When the fuse is blown, my power windows don't work along with my turn indicator. I know it says in my owner's manual that the fuse is for the turn signal, but my power windows are affected also. I have to replace the fuse between 5 minutes and 3 days apart. Nothing else is affected by the blown fuse.
Aug 2, 2010 at 2:09 AM
