2004 Kia Rio what do i do?
112,000 MILES • 4 CYL • FWD • AUTOMATIC
KIARIO
my kai blew the head. i had it resufaced and pressure tested. i have it reinstalled now. the valve timimg is set. i replaced all the gaskets and the cam position sensor. had to buy new battery. during clean up i wiped off the firing order. but the car will start. i have to pump the trottle as fast as i can while tirning the key for 30 to 60 seconds before it starts. the first time it started it sounded good except after idle when i accelerated the engine stalled a moment before increasing rpm. since then i put the belts, air filter and timing cover back on and now it will bearly start and when it does it sonds loaded down. if i take my foot off the gas pedal it dies. what should i do to fix this? also can you tell me what the firing order is on the coil
Aug 26, 2009 at 7:34 AM
  • 110,248 POSTS
1-3-4-2 is the firing order and they go in succession 1-4 starting at the pulley. Check that and let me know what you find. Also, have you checked for vacuum leaks and has the check engine light come on?
Oct 12, 2009 at 3:31 AM
