2004 Kia Rio starting
SHORTBAG
Electrical problem
2004 Kia Rio 4 cyl Front Wheel Drive Manual
my car won't start when it rain or snow.
Dec 3, 2009 at 11:32 AM
  • 75,988 POSTS
Rain, Snow or Shine-Do below to determine if its fuel or spark issue-it will lead you to somewhere
Disconnect a sparkplug wire or 2 and ground it to the engine -have helper crank engine over-do you have a snapping blue spark? If so-you have a fuel related problem, check the fuel pressure to rule out the fuel filter/fuel pump/pressure regulator and listen to the injector/s are they pulsing or hook up a noid light. No snapping blue spark continue to troubleshoot the ignition system-power input to the coil/coil packs,coil's resistances,cap and rotor /distributor pick-up coil, ignition control module, ECM,Ignitor camshaft and crankshaft sensors- Note: If it doesn't apply disregard it
Dec 3, 2009 at 10:08 PM
