2003 Kia Rio what could be wrong?
105,000 MILES • 4 CYL • FWD • MANUAL
HANDYMANWANABE
The car all of a sudden developed an uneven engine sound and the check engine light came on, it has a lot less power but still runs uneven.
runs smooth on neutral, but when pulling the weight, it is weak and a little uneven
Jan 24, 2010 at 12:26 AM
DGAGNE
I have the same problem man.
If you haven't already maybe change the timing belt. From what I have read online, that is a common problem with this car.
I think the recommended change of the timing belt is supposed to be every 100,000 km (60,000 miles). I have also read a lot of people not waiting that long because these belts are breaking earlier and that the problem could really damage the engine.
I will get mine replaced in the next month and see how much it will be, if it fixes the problem and then I will message you back. Also, if you find out what your problem really is, tell me ok?
fred.eval@yahoo.com
Jan 30, 2010 at 7:50 AM
