2003 Kia Rio cant fix p0101
130,000 MILES • 4 CYL • FWD • AUTOMATIC
TINYSKIA
Hi I have a 2003 kia rio 1.6 dohc with 130,000 miles on it all maintenance is up to date I got a code p0101 i put on 3 mass air flow sensors 2 from a local auto parts store the 1 the last one from the dealer cleared the code it comes back I changed the tps and cleared the code it still comes backs. It has a new air filter and I cant find any vacuum leaks. right before the code sets the will be a slight hesitation on take off not every time but a few times during a ride. Then the light will be set if i clear the code the hesitation will go away but when it comes back then the code p0101 sets.
Please help me i have tried everything.
David
Mar 2, 2010 at 3:50 AM
RASMUSSEN317
While doing research into my p0501 speed sensor code. I found A TSB about reprogramming the ecm to fix a continuos p0101 code. It requires a trip to the dealer, but should fix it.
Apr 7, 2010 at 10:47 PM
