were is the knock sensor located on a 2003 kia roi
Sep 4, 2009 at 4:37 AM
✓Experienced Mechanic
2001-2005 Under the intake manifold support bracket.
Disconnect the negative battery cable.
Remove the intake manifold support bracket.
Disconnect the sensor connector.
Remove the sensor from its mounting.
To install:
Installation is the reverse of the removal procedure.
Tighten the sensor to 12-18 ft. lbs.
Oct 12, 2009 at 6:21 AM
