2003 Kia Rio
VANMETER_420
2003 Kia Rio 4 cyl Front Wheel Drive Automatic
engine codes read that i need to replace knock sensor....where is it?
Jun 22, 2009 at 6:33 AM
  • 110,251 POSTS
It is under the maniflod support:
2001-2005
Disconnect the negative battery cable.
Remove the intake manifold support bracket.
Disconnect the sensor connector.
Remove the sensor from its mounting.
To install:
Installation is the reverse of the removal procedure.
Tighten the sensor to 12-18 ft. lbs.
Oct 12, 2009 at 5:01 AM
