2002 Kia Rio uneven wear
2002 KIA RIO
85,000 MILES • 4 CYL • 4WD • AUTOMATIC
RISHIS4EVER
The front and rear passenger tires are at 2/32 while the tires on the drivers side are 4/32. Bought 4 tires at the same time. What can cause this? Just had rear brakes installed and I think calibers? Not sure. Thank you
Oct 19, 2010 at 8:14 AM
SATURNTECH9
  • 30,869 POSTS
Have you been rotating the tire's regularly?If so did you rotate them just front to back?The tire's stayed on the side you put them on the entire time they were were on the car?
Oct 19, 2010 at 8:23 AM
RISHIS4EVER
The tires are rotated about every other oil change. They are changed, to my knowledge, in the "x" formation. Thank you for replying to my question.
Oct 20, 2010 at 2:47 AM
SATURNTECH9
  • 30,869 POSTS
The best way to explain the one side wearing down a little faster then the other is your car has what's called a driven wheel where it does most of the work and wear's the one side down faster then the other.Same thing happens on rear wheel drive car's or truck's unless they have limited slip.So another word's it would be normal for your car.As long as the wear is even all the way across your fine.
Oct 20, 2010 at 4:34 AM
RISHIS4EVER
Thank you so much for your response. It is a strange situation, I never rotated tires before, and when I do - this happens!
Oct 21, 2010 at 8:42 AM
SATURNTECH9
  • 30,869 POSTS
Your welcome It's not strange just common when you rotate your tire's from front to back.
Oct 21, 2010 at 12:43 PM
RISHIS4EVER
Thank you, I understand, the tires were not rotated in the "x" pattern as I was told.
Oct 22, 2010 at 3:20 AM
