2002 Kia Rio speedometer and milage
2002 KIA RIO
ABCDEFGHI
Electrical problem
2002 Kia Rio Two Wheel Drive Manual 70000 miles
Ive just got a Kia Rio and the Speedometer is not working or the milage counter is not counting. I need to know how to fix this problem. Also how to get to the Speedometer??
Thankyou.
Jan 27, 2009 at 3:57 AM
2CARPRO JACK
  • 11,533 POSTS
Most of the time the VSS (vehicle speed sensor) sends signal to the computer, which in turn tells the speedo/odo what to read. Your best bet will be to have it put on a scanner to see if the PCM (computer) is getting the signal from the VSS, then we can go from there, might not be a problem with the instruments, but need to be sure the other end is working first
Jan 27, 2009 at 11:37 PM
