New question to "the alternator is not installed correctly. im assuming when the engine was replaced the mechanic who installed it left out a spacer for the alternator and when the alternator is now being installed when the bolts are tightened the alternator case is being distorted causing it to fail. i have seen this before."
If the spacer is installed, will I need a new alternator
or is it ruined by the incorrect installation?
May 17, 2008 at 7:25 AM
