I cannot find the fill plug for the trans. could you tell me if there is one and where it is at?
Dec 30, 2008 at 7:30 AM
DAVE H
✓Experienced Mechanic
DRAINING & REFILLING
Place drain pan under transaxle drain plug. Remove drain plug and allow fluid to fully drain.
Install drain plug. Tighten to specification.
Remove ATF level gauge and pour specified fluid to appropriate level.
Check fluid level.
