2002 Kia Rio Engine Check Light on
KATIE0
  • 2002 KIA RIO
Engine Mechanical problem
2002 Kia Rio Engine Size unknown Wheel Drive Type unknown Automatic 80444 miles
my car didn't start OK this morning. Started after 2 starts. And the Engine Check Light came on. Was driving sluggishly and then the engine stopped but the car was still moving, slowly. I turned it off and started again, managed to bring it back home. I later, check the gas pump cap, it was not properly capped. I capped it and the car started driving and picked up speed but the Engine light is still on. Pls advise me on what to do. Thanks
Sunday, March 30th, 2008 AT 6:26 PM
MASTERTECHTIM
  • 4,750 POSTS
It has nothing to do with the gas cap. Sounds like you have a engine skip. You need to get the vehicle scanned for codes(autozone does it for free) then get back to us with the codes
Sunday, March 30th, 2008 AT 6:31 PM
KATIE0
Hi, the codes given to me at the Autozone is P0335, it says the problem has something to do with the Crankshaft postion sensor condition. Pls explain to me what it means. Thanks alot
Sunday, March 30th, 2008 AT 7:32 PM
MASTERTECHTIM
  • 4,750 POSTS
Well thats the problem. This sensor needs to be changed. The sensor tells the computer when to fire the spark plugs and set the ignition timing, when its bad it messes everything up. Hope this helps
Sunday, March 30th, 2008 AT 7:35 PM
KATIE0
Also the Engine Check light went off on my way back.
Sunday, March 30th, 2008 AT 7:36 PM
KATIE0
Hi, if the Engine Check light stopped appearing after showing for several hours, does it mean that the problem is no longer there. Thanks alot
Sunday, March 30th, 2008 AT 8:10 PM
