2002 Kia Rio
WESTIEROBERT
Engine Performance problem
2002 Kia Rio 4 cyl Front Wheel Drive Manual
i drove 210 miles parked my car went to start it 5 hours later it turns over but dont start what can i do
Jul 23, 2010 at 11:09 AM
  • 75,988 POSTS
Cranks but no start condition-do below to determine whether it's fuel or spark problem.
Get a helper disconnect a sparkplug wire or 2 and ground it to the engine at least 3/16 away from ground -have helper crank engine over-do you have a snapping blue spark? If so-you have a fuel related problem, check the fuel pressure to rule out the fuel filter/fuel pump/pressure regulator and listen to the injector/s are they pulsing or hook up a noid light. No snapping blue spark continue to troubleshoot the ignition system-power input to the coil/coil packs,coil's resistances,distributor pick-up coil, ignition control module, cam and crank sensors and computer Note: If it doesn't apply disregard it.
Jul 23, 2010 at 1:40 PM
