How much does it cost to replace a caliper on one side? Can I replace the caliper without replacing the front brake pad?
Jan 27, 2010 at 10:19 AM
BLUELIGHTNIN6
✓Experienced Mechanic
Yes you can replace just the brake caliper if you choose to do so, however it is a good idea to go ahead and replace the pads if they are worn enough to need replacing..
