2001 Kia Rio heater
2001 KIA RIO
103,000 MILES • 4 CYL • FWD • AUTOMATIC
REDNECK7928
when i turn my heater on the radiator fan kicks on and wont turn off.it works normally when the heater is off.therefore my heater continuosly blows cold air because the radiator fan wont shut off when heater blower is on.i was wondering why?
Dec 14, 2008 at 5:47 AM
JAMES W.
  • 2,394 POSTS
When the selector control is set for heat and the fan control is off, does the cooling fan still run? Also, if the heat/ac are both turned completely "off", does the cooling fan run? Please advise.
Dec 14, 2008 at 8:10 AM
REDNECK7928
the radiator fan works normally untillthe blower motor is turned on.
Dec 14, 2008 at 9:30 AM
JAMES W.
  • 2,394 POSTS
The only place the blower motor and the cooling fan come together is at the "engine control module". This unit it located under the dash behind the left kick panel. If a diode in this module blew, the blower fan circuit could backfeed the cooling fan circuit and cause your problem. Hope this helps.
Dec 14, 2008 at 10:38 AM
