1981 Kia Rio starter solenoid
HOSSEINFALLAH
Electrical problem
1981 Kia Rio 4 cyl Front Wheel Drive Manual
hi
i have bought several time starter solenoid ,but always after fixing it when i want to tighten the nut of buttery terminal .it will be rotate freely with it's screw from inside of it.so could you pls tell me the correct torque of tightening the nut with tolerance.
thanks in advance
May 29, 2008 at 6:25 PM
  • 31,937 POSTS
Hi there,
I don't think there is a set torque for this item, just do up with a spring washer installed and just nip it up, the washer will stop it from coming loose.
Mark (mhpautos)
May 29, 2008 at 6:52 PM
