Check engine light turned on
125,346 MILES • 6 CYL
KIMINIJONES
  • 11 POSTS
The check engine light came on the codes were for the rear catalytic converter, so we had it replaced along with the sensors, and the light came back on. What could be the problem?
Sep 10, 2021 at 8:14 AM
  • 110,248 POSTS
Is it the same code as before? Also, do you have the code? If you do, let me know what it is.
As far as the catalytic converter, are you experiencing any odd smells, loss of power, or anything out of the ordinary?
Here is a link that explains the most common symptoms of a faulty converter. Take a look through it.
https://www.2carpros.com/articles/bad-catalytic-converter-symptoms
Let me know what codes are showing up. That will help me narrow things down.
Sep 10, 2021 at 1:43 PM
KIM JONES2
  • 5 POSTS
I am not sure what the exact code number is but it was explained as the rear catalytic converter. And yes after I have been driving the van for awhile I get a strong gas smell in the cab but no loss of power. And I read another person's complaint of having to fight to fuel up, I also have that problem.
Sep 10, 2021 at 2:18 PM
KIM JONES2
  • 5 POSTS
I am trying to get the emissions done, they didn't get any reading on the computer because it was reset after the new catalytic converter was put on, so they wouldn't let me test.
It has been a nightmare.
Sep 10, 2021 at 2:20 PM
  • 110,248 POSTS
The idea that you smell fuel can be several different things. Also, since they are unable to find any new codes, how do they know the converter is the problem again? If you are smelling fuel, it could be a leak or an emissions component issue. The idea that you can't fill the fuel tank easily is likely related to the EVAP system.
Here is what I need you to do: First, make sure there are no fuel leaks. Check for evidence of a leak under the hood and vehicle. Most times, fuel evaporates before you get the chance to see it. However, it usually stains the area it leaks on.
Next, if there are no fuel leaks and the vehicle is safe to drive, we need to drive it until the check engine light comes on. That should point us to the issue. It is likely going to indicate something with the EVAP system (evaporative emissions system).
Also, if it is a converter-related issue again, the smell may indicate too much fuel being burned by the engine. If you have a misfire, raw fuel can get into the converter and damage it, so that is another possibility.
Overall, we need to see if codes are set. Otherwise, it becomes a guessing game. But, we need to make sure there are no fuel leaks.
Sep 10, 2021 at 3:05 PM
KIM JONES2
  • 5 POSTS
Hello again, I finally got the code "P0431" and it says "secondary DTC is P0455.
Maybe that will help on my part, get back to me please.
Sep 13, 2021 at 6:05 AM
  • 110,248 POSTS
Kim,
The P0431 indicates a failed catalytic converter, bank 2. If that is the one that was replaced, it should have a warranty. I attached a pic below showing the converters.
Now the P0455 indicated a large evap leak. This is in the evaporative emissions system. Since it is a large leak, it shouldn't be too hard to find. Make sure the fuel cap is tight, check the fuel filler tube for rust damage, Also, open the hood and locate the EVAP charcoal canister. It is near the brake master cylinder. Check the vacuum hoses attached to it for damage. Also, follow the hoses to the engine and one to the fuel tank and check for issues.
Pic 2 shows the charcoal canister.
I can't be sure, but there is a chance if we can get this leak fixed, the converter will be fine. A large leak is causing an engine vacuum leak. If the fuel mixture is lean enough, this could be throwing the oxygen sensors off causing the code.
Let me know what you find. Also, here is a link you may find helpful. It explains how to test for an engine vacuum leak.
Sep 13, 2021 at 12:31 PM
