Kia Pride Scan tools & interface
2,147,483,647 MILES • 1.3L • 4 CYL • 2WD • MANUAL
HAMED-PC
Hi
Good day
I have Car KIA pride 4 Cylinder . 1.3L . include Ecu Siemens and 20pin diagnostic connector under the hood
I need How to Connect to this model For see sensor detail and ecu parameter Live data ? this model Care of KIA witch protocol support ? i mean use ISO14230-4 (KWP2000) , ALDL , ISO9141-2 , SAE J1850 VPW , SAE J1850 PWM ,??? .
i Don't know Witch interface compatible this model and how to connect pin to pin to this connector . i need electronic diagram
thank you and Best regards
Jan 1, 2016 at 11:01 AM
HMAC300
  • 48,601 POSTS
it should be OBD2 and aldl is under lh side of steering column.
Jan 1, 2016 at 10:09 PM
HMAC300
  • 48,601 POSTS
it's obd2 and aldl means the diagnostic link connection your connector will only hook up to the 16 pins not all 20. we don'thave that model in U.S. so no info on it but it your connector should hook up to everything except the 4 top connectors also look on underside of dash lh side. they are all supposed to be there.
Jan 2, 2016 at 1:31 AM
