Kia picanto breaks
30,000 MILES • 1.1L • 4WD • MANUAL
KIA2007ALSB
I purchased this vehicle three years ago from a friend of mine and it was working absolutely fine.
Recently I have Stared hearing a crack voice when I slow down using the breaks and the light of abs turn on.
I changed the pads and plates for the breaks but that dose not help.
Please could advice me what to do?
Should I change the ABS Pumps
Thank you
Apr 11, 2016 at 8:03 PM
HMAC300
  • 48,601 POSTS
no don't change any parts until it is scanned for codes to see what is wrong with ABS. it can be asensor bad, rust etc. check for broken rust pieces by sensor as they are magnetic and will throw a code as rust will stick to it. but get it scanned first to see what problem is.
Apr 11, 2016 at 11:03 PM
KIA2007ALSB
Thank you for your replay
but when i put my foot on the clutch and brake it judders to a stop...and abs light intermittently coming on.
when i have removed the ABS fuse the problem disappear.
Apr 12, 2016 at 12:50 AM
HMAC300
  • 48,601 POSTS
that's because when your remove the abs fuse it no longer works as abs. have this scanned for codes there is no way around it your reflexes are not faster than an abs unit. if it's a bumpy road it may effect the way abs works. Something is activating the abs that is why it is juddering like you call it.
Apr 12, 2016 at 2:54 AM
