relieve tension on serpentine belt 3.5 sedona 2002
2002 KIA
FSCHARLIE
  • 5 POSTS
Well I don't feel so stupid now seems like none of you car buffs knows anything about kias either. at least none of you tried to answered my question of how to take the tension off the belt. :twisted: :( :(
May 29, 2006 at 1:52 PM
CODY-ODY
  • 57 POSTS
well for one the sedonna has 2 belt! a power steering belt,tensioner pulley and crank pulley, then you have the other on for the altinator a/c and crank pulley.This one also contains a tensioner pulley and an idler pulley. If you couldn't figure out how to adjust this one I suggest you don't do too much too your vehicle as it a very simply system! you loosen the 14 mm bolt on the tensioner( just beside the ac compressor) then you have an adjusting bolt just underneath the tensioner that you can either tighten or loosen it!
Jun 18, 2006 at 1:25 AM
