Overheating
KIA
JAZZYTY
Kia Sportage 2002 92,000 mileage
When I am waiting (not moving) the needle for the thermostat rises to the hot level. When I start moving again it goes back to normal. It has not overheated yet.
Also, should water ever be added to the radiator?
Nov 14, 2007 at 1:01 AM
  • 75,988 POSTS
Please add coolant till properly filled first the radiator and then the resevoir bottle. Might want to replace the thermostat and make sure the electric fans are coming On.
Water will ruin your cooling system. They use Antifreeze and make sure its the correct type.
Good Luck
Nov 14, 2007 at 5:49 AM
