2000 Kia Sephia Door Won't Latch in Winter
KIA
PAEMT149565
Dear sir:
My girlfriend has a 2000 Kia Sophia and in the winter time the driver's door will not latch. We took it to a local dealership and they said there nothing they can do. But this to me is a very big safety hazard. I found out a couple other people are having the same problem. The dealership stated there is water getting into the latching mechiz. and freezing up. Is there anyway to solve this buy using heave grease and lub everthing up or get it replaced? Plz help me I don't want my girlfriend driving like this for to much longer. Thank you for you help.
Kevin Kuhn
EMT/FF
Dec 7, 2006 at 5:01 PM
BRUCE HUNT
  • 3,754 POSTS
I would say this is a design flaw. There have been several such over the years. What to do about it. Check the web to see if you can locate a possible recall on the item. Most of the mechanics don't know or care about the problem and don't have the time to find out about any recalls or impending recalls. The best I could offer is that you use a light silicone grease on the latch mechanism in the door. There is a spray grease I have found. Get the car warmed up in a garage to allow the moisture to evaporate and apply the grease.
Good luck!
Dec 11, 2006 at 2:12 AM
Suggested Repair
Check for a possible recall. Warm the car in a garage so moisture can evaporate, then apply a light silicone spray grease to the door latch mechanism.
Conversation Summary
The owner of a 2000 Kia Sephia reports that the driver's door will not latch in winter. A dealership attributed it to water entering the latch mechanism and freezing, and said nothing could be done. The expert describes it as a known design issue, suggests checking for a recall, and recommends warming the car so moisture evaporates before applying light silicone spray grease to the latch.
