COOLING FAN NOT COMING ON
KIA
RIVERS41
2005 KIA SEDONA THE A/C COOLING FAN COMES ON WHEN A/C IS TURNED ON THE OTHER COOLING FAN NEVER COMES ON AND TEMP GUAGES DOES RISE WHAT COULD BE THE PROBLEM WHEN THE COOLING FAN DOESNT COME ON?
Jun 1, 2007 at 6:17 AM
TURBOTUFF20G
  • 98 POSTS
i would 1st have all fuses checked out, then i would take a test light and touch the 2 wires going to fan while A/c is on to see if your getting any power to the fan, but be very carefull working around fans.
Jun 1, 2007 at 10:43 AM
RIVERS41
[quote:d5446bdf0f="turbotuff20g"]i would 1st have all fuses checked out, then i would take a test light and touch the 2 wires going to fan while A/c is on to see if your getting any power to the fan, but be very carefull working around fans.[/quote:d5446bdf0f]
Jun 2, 2007 at 4:33 AM
RIVERS41
2005 KIA SEDONA ALL FUSES ARE IN TACT,I PROBE THE ELECTRICAL ORANGECOLOR WIRE ON THE HIGH FAN FOR THE A/C AND IT LIT UP THE DRIVERS SIDE I PROBED THE WIRE NO CURRENT AT ALL?I DID NOTICE THE RELAY MADE A ACTIVATION CLICK ON THE FAN THAT DIDWORK THE OTHER LOW FAN RELAY SEEMED HOT TO TOUCH AND NO ACTIVE NOISES I DID PULL IT OUT AND PUSH IT BACK IN I HEARD A OR FELT A HEAVY ELECTRICAL SURGE NOISE,IS THERE AWAY TO STRAIGHT WIRE THE FAN TO SEE IF IT COMES ON AT ALL?
Jun 9, 2007 at 5:51 AM
