2002 Kia Spectra, no gear shift
2002 KIA
CRISTAL_MJ
I have a 2002 KIA Spectra with 105,000+ miles. The car will start, air works, will go in neutral, but will not drive, or reverse. Feels like its permantely stuck in park. IS it the transmission or (hopefully) something else?
Apr 8, 2007 at 5:58 AM
DAVE H
  • 13,384 POSTS
No Forward & No Reverse
Fluid level and condition, shift linkage, low hydraulic pressure, oil filter plugged or damaged, valve body, incorrectly tightened valve body bolts (cross-leaks), pump assembly, pump shaft broken or damaged, flexplate, idler gear, park mechanism stuck or damaged, final drive and differential assembly or planetary gear sets.
Apr 11, 2009 at 1:36 AM
