2000 Kia Sportage Spark Plug Location
2000 KIA
HELPINGFRIEND
I'm trying to help a friend tune up her 200 kia sportage. Where the heck are the spark plugs located? I was told that the car does not have a distributer and the plugs should be easy to locate "somewhere on top of the motor" but I don't see where they would be. Do I have to dismantle all kinds of stuff to get at them?
Please help!
Jan 22, 2006 at 5:55 AM
2CARPRO JACK
  • 11,533 POSTS
under the coils, maybe under a plastic cover
Feb 2, 2006 at 7:09 AM
CODY-ODY
  • 57 POSTS
Its not straight forward: first you have to remove the top part of the intake that holds the throttle and cables and the rubber black cowl(large tube) that goes to it ,then remove the long black plastic cover that runs down the center of the engine. From there you must remove 2 coils and 2 ignition wires and there you'll find the plugs.
Jul 10, 2006 at 12:01 PM
Suggested Repair
Spark plugs are under the coils, often beneath a plastic cover. Remove the upper intake that holds the throttle, cables, and rubber intake tube, then the long black plastic cover down the center of the engine. Remove the two coils and two ignition wires to reach the plugs.
Conversation Summary
The owner of a 2000 Kia Sportage could not find the spark plugs and was told the engine has no distributor and the plugs are on top of the motor. Experts said the plugs are under the coils, possibly under a plastic cover. Access requires removing the upper intake and throttle assembly, the center plastic cover, two coils, and two ignition wires.
