2000 Kia Sephia sqawky then broke belt
2000 KIA
KEITH D SWARTZ
I have a Kia Sephia LS Sedan 4 door - year 2000, w/ 93,542 miles on it. It has generally been a real dependable car.
Just recently the belt [found out when it broke it was Alternator belt] began to squeak intermittently. It did this for about 50 miles and then it broke. Put new belt on and it is STILL squeaking intermittently. Please help me locate the cause before belt breaks!
Mar 5, 2007 at 8:59 AM
MUZICFREAK77
kia's needa be tightened really, really well. especially the alternater belt. up by the alternater take that nut and tighten it as hard as you manually can. that nut backs off and loosens the belt, thats whats causing the squealing. or use a locknut, i went through like 6 of those belts before i figured it out, now the problems stopped lol.
May 22, 2007 at 1:20 PM
KEITH D SWARTZ
[quote:c6d9b50b6e="muzicfreak77"]kia's needa be tightened really, really well. especially the alternater belt. up by the alternater take that nut and tighten it as hard as you manually can. that nut backs off and loosens the belt, thats whats causing the squealing. or use a locknut, i went through like 6 of those belts before i figured it out, now the problems stopped lol.[/quote:c6d9b50b6e]
[quote:c6d9b50b6e="Keith D Swartz"]Thank-a-you, thank-ayou, thank-a-you so very-much! Doesn't it usually turn out to be the SIMPLEST FIX usually fixs the LARGEST OF OUR PROBLEMS. My family, me, and mostly my daughter thank-you very very much![/quote:c6d9b50b6e]
May 23, 2007 at 3:37 PM
