My son has a 2000 Kia Sephia, 125,000 miles, 1.8L engine, 5 speed manual transmission.
It will start, but has no power. It dosen't want to go above 3000 rpm. 2 months ago it got a new head gasket and timing belt. Today I installed new plugs, wires and coil packs, fuel filter, and air filter. It has not really improved. I checked the codes and only showed a misfire on two cylinders prior to changing everything.
Is the catalytic converter the next most likely problem ? What else should I look for ?
Thanks in advance
Thanks in advance
Feb 3, 2007 at 8:39 AM
