1999 Other Kia Models
1999 KIA
SENECA MCKINNIE
Engine Performance problem
1999 Other Kia Models Front Wheel Drive Automatic 88,000 miles
how do access the fuel pump which is by the gas tank on a kia sepha
May 17, 2008 at 9:04 AM
DAVE H
  • 13,383 POSTS
FUEL PUMP
Removal & Installation (Fuel Delivery Module - Sephia)
Fuel pump is located in fuel delivery module along with fuel sender unit. Release fuel system pressure. See FUEL SYSTEM PRESSURE RELEASE . Disconnect negative battery cable. Remove rear seat cushion. Disconnect electrical connectors and remove access cover. Disconnect fuel hoses from fuel delivery module. Remove 6 screws and lift fuel delivery module from fuel tank. To install, reverse removal procedure.
Apr 8, 2009 at 5:06 AM
