What is the correct position of the distributor on a Kia Sephia 1800cc, manual transmision.
Sep 15, 2008 at 3:09 AM
DAVE H
✓Experienced Mechanic
there is no adjustment possible to the distributor !!
Ignition Timing Advance Control
A PCM-controlled Electronic Spark Advance (ESA) system is used. The PCM determines ignition timing based on signals from input devices
