What is the correct position of the distributor on a Kia Sephia 1800cc, manual transmision.
Monday, September 15th, 2008 AT 10:09 AM
DAVE H
MECHANIC
There is no adjustment possible to the distributor !
Ignition Timing Advance Control
A PCM-controlled Electronic Spark Advance (ESA) system is used. The PCM determines ignition timing based on signals from input devices
