1996 Other Kia Models dificult break problems
1996 KIA
KIRKMASON
Brakes problem
1996 Other Kia Models 4 cyl Four Wheel Drive Manual
I change the breaks and master cylinder on my kia ceres truck, my break pedal is hard when engine is not working, but when engine is started the break pedal goes to the floor and that is where the breaks constantly holds, floor. I bleed the breaks numberous times , with the engine started also but the same result, is it a possibility tha my proportioning valve is bad or going bad. I am desperate to have this problem solved.
Jul 24, 2010 at 2:13 PM
AUTOZONEBRAKESEXPERT
  • 47 POSTS
If it seems to take a long time to stop the car when applying the brakes, where you have to push the pedal down hard to come to a complete stop:
* This condition is often due to ‘brake fade,’ which occurs when the linings become too hot. It may be caused by linings that are too thin or brakes that are overworked.
* This condition may also be caused by air in the hydraulic system, a fluid leak in master cylinder, a hose or line leak in system, and/or if the brakes misadjusted.
* This may also be an indication that the rear (or front) brakes that are not operating as designed. This requires the front brakes to work harder resulting in overheating and longer stopping distances.
Apr 10, 2011 at 1:54 AM
