2009 Kia Optima carpet stain
16,000 MILES • 4 CYL • 2WD • AUTOMATIC
DIAL1
It just appeared. a white like substance outlining the front drivers side in between the seat around the back floor. on the passager side it is only around the rear floor. This is not from being brought into the car. The white line is 4 to 5 inches off the floor. The air condition was checked for a blocked drain - it was not. The line is squiggly and seems to led from heat/air ducts under the passager seat. I tried to remove it but it came back.
Sep 16, 2010 at 4:18 AM
  • 110,248 POSTS
Has anyone checked to see if the heater core is leaking?
Oct 14, 2010 at 12:13 AM
