2005 Kia Optima engine will not turn over
BELKI
Engine Mechanical problem
2005 Kia Optima 4 cyl Front Wheel Drive Automatic
my car started and was running but when i put it into reve
se the car died and will not turn over now
i have done that starter has power but will not turn engine over!!!!
Jan 27, 2009 at 8:43 PM
BMRFIXIT
  • 19,053 POSTS
Try and get a jump
if start with a jump and then stalls after cable removed then I would suspect charging system
check fuses
check alternator
if battery fully charge and engine doesn’t turn over
check fuses and starter
Jan 27, 2009 at 9:08 PM
