2005 Kia Optima Automatic Window
10,020 MILES • 4 CYL • FWD • AUTOMATIC
MARE621
Window on Drivers side only was repaired twice for being off track and is broken again will only go partially up. I am now being told I would need a window regulator put in costing $400. Is this correct
Jul 27, 2010 at 2:21 AM
  • 110,248 POSTS
The regulator keeps the window straight when being moved. The price sounds a little high, but that will most likely fix the problem.
Oct 14, 2010 at 12:31 AM
