2005 Kia Optima Aircondition is Not Cooling
120,334 MILES • V12 • AWD • AUTOMATIC
ASIMKHAN_89
Hello Sir,
Just wanted to ask that why is my car airconditon not cooling so fine?
As the conditon of the car is awesome.
And one more thing, i want to ask is that when i stop my car my car is vibrating from inside.
I'll be waiting for the positive and helpful replies from you teachers :)
Regards,
Asim
E-mail: asimkhan_89@hotmail.com
Oct 8, 2010 at 8:07 AM
  • 110,248 POSTS
Has the AC system ever been recharged?
As far as the vibration, when was the last tune up? Have you checked for vacuum leaks? Does it vibrate in park or neutral?
Oct 14, 2010 at 12:05 AM
ASIMKHAN_89
[quote:02f2f94d4b="Jacobandnickolas"]Has the AC system ever been recharged?
As far as the vibration, when was the last tune up? Have you checked for vacuum leaks? Does it vibrate in park or neutral?[/quote:02f2f94d4b]
First of all thanks for your Reply Sir!
Well no i dont think soo it has been recharged before.And yeah if i would for the Gas will it work for me or not?
And yeah regarding the vibration thing "No it dont vibrates when its on Parking or Neutral, it vibrates when its on Drive and still im not moving. Please kindly help me in this.
Thanks alot for the Kind and Helpfull reply Sir.
Regards,
Asim
Oct 14, 2010 at 9:41 AM
  • 110,248 POSTS
Chances are the AC system needs to be recharged. If it is low on freon, this can happen.
As far as the vibration, it seems to be coming from a low RPM when in gear. What I suggest is to start by checking for vacuum leaks. If there are none, have the idle air control motor checked or consider a tune up.
I must say that as a result of the small engine on these vehicles, often there is some vibration with the AC on, in gear, and at an idle.
Oct 14, 2010 at 11:57 PM
