2004 Kia Optima timing belt replacement
102,000 MILES • 4 CYL • FWD • AUTOMATIC
AANDM52089
There is a pin in the crank shaft gear, what i have read indicates that this should be at twelve o'clock as should the cam shaft gears (dohc) is this correct? the cam gears have markings on them. or is ther an off set to them?
Aug 27, 2008 at 2:11 AM
  • 110,251 POSTS
Go to the belt routing diagrams site on this page and it will identify where the marks should be.
Jul 11, 2009 at 3:47 PM
