2004 Kia Optima OBD Code
98,000 MILES • 4 CYL • FWD • AUTOMATIC
QZDESERTRAT
Unsure if related, however engine has been a bit troublesome--stumbling occasionally on take off, more so when cold but still noticeable at times at operating temp. A few days ago check engine light came on, stayed on for 3 days, then went out. Today (day after it went out) I ran the scanner and got a P0466, which posts up as a generic "purge flow sensor circuit range/performance."
I did not clear the code.
Background: I have changed plugs within the last 10,000 miles; air filter changed and within range. Car does have frequent idling for minutes at a time with air conditioner running, lots of short stops. Also run several times a week at freeway speeds averaging 25 mile trips.
Oct 7, 2010 at 4:38 AM
DOCHAGERTY
  • 9,606 POSTS
A purge valve stuck open could certainly cause a driveability issue, the driving habits should not be a factor in the cause of the faults being set for the purge flow sensor.
Oct 8, 2010 at 4:18 PM
QZDESERTRAT
Since the purge valve code hasn't popped up again, the check engine light is no longer lit, do I follow up in some way on this, or just assume it was a temporary glitch?
Oct 9, 2010 at 3:24 AM
DOCHAGERTY
  • 9,606 POSTS
I would say follow up if it happens again. Its what we call an intermittent pain in the................well, you get the picture.
Oct 23, 2010 at 10:59 AM
